Manufacturing Solutions
To create surfaces by interpolating linearly between lines and nodes
1.Select the Surfaces panel, ruled subpanel.
2.Set the first collector to line list and select the lines in the proper order.
3.Set the second collector to node list and select the nodes in the proper order.
4.Optionally, check on or off the auto reverse checkbox.
5.Click create.
6.To undo, immediately click reject.
