Manufacturing Solutions
To create surfaces by dragging lines along their normal
1.Select the Surfaces panel, drag along normal subpanel.
2.Set the collector to line list and select the lines in the proper order.
3.Specify how the new surfaces will be organized by setting the create in option.
4.Set the distance method to determine how the drag distance is specified.
If set to uniform, enter the constant value.
Or
If set to variable, enter the start and end values.
5.The start of the line list is indicated by the end of the chain that has the arrow after selecting the lines, but can be reversed using the switch start point option.
6.Specify the link type option.
7.Click drag + or drag -.
8.To undo, immediately click reject.
