Manufacturing Solutions
To create spline/filler surfaces from lines
1.Select the Surfaces panel, spline/filler subpanel.
2.Optionally, check on or off the auto create (free edges only) checkbox.
3.Set the collector to lines and select the relevant lines.
4.Optionally, check on or off the keep tangency checkbox.
5.If the auto create (free edges only) checkbox is off, click create.
6.To undo, immediately click reject.
