Manufacturing Solutions
To create partial cylinder surface primitives
1.Select the Surfaces panel, cylinder partial subpanel.
2.Click on the bottom center collector and select a node from the graphics area.
3.Click on the normal vector collector and select a node from the graphics area.
4.Click on the major axis collector and select a node from the graphics area.
5.Enter the base radius value.
6.Enter the height value.
7.Enter the start angle value.
8.Enter the end angle value.
9.Enter the axis ratio value.
10.Click create.
11.To undo, immediately click reject.
