Manufacturing Solutions
To create nodes between nodes in a list of nodes:
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
1.Select the between subpanel.
2.Select the nodes between which you want to create a node or nodes.
HM_Panels_bmp00078
3.To create evenly spaced nodes between nodes:
-        Click number of nodes.
-        Enter the number of nodes you want to create between the nodes in the list of nodes.
4.To create nodes with biasing:
-        Click the switch after bias style: and select linear, exponential or bellcurve.
-        Click the data entry field after bias intensity = and enter the desired value.  For more information on the biasing options, refer to Element Biasing in the User’s Guide.
5.Click create.
HM_Panels_bmp00079
Evenly spaced nodes.
createnodesbiased
Biased nodes.
Undo
Click reject.
