Manufacturing Solutions
To create full cone surface primitives
1.Select the Surfaces panel, cone full subpanel.
2.Click on the bottom center collector and select a node from the graphics area.
3.Click on the normal vector collector and select a node from the graphics area.
4.Enter the top radius value.
5.Enter the base radius value.
6.Click create.
7.To undo, immediately click reject.
