Manufacturing Solutions
To create a node or point by specifying the coordinates
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
1.Select the type in subpanel.
2.Click the value following x = and enter the x coordinate of the new node by typing in the value, or click x = and select a node from the graphics region to extract the x value of the node.
3.Repeat the last procedure for the y and z coordinates.
4.Click system = and specify the system in which you want to create the node, if other than the global system.
5.Click create node or create point.
Undo
Click reject.
When you create a node, it is created in the specified or global system.  The node is updated to reflect any changes that are made to the designated system.  Points are not updated to reflect changes made to the original coordinate system.
