Manufacturing Solutions
To create a node on a line or surface:
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
1.Select the pick geom subpanel.
2.Click the switch and select either lines or surfs.
3.Indicate the line(s) or surface(s) where you want to create a node by selecting the entity on your model or select lines or surfs and choose from the extended entity selection menu.
HM_Panels_bmp00074
4.Use the mouse to select the position on the line or surface where you want to create the node(s).
HM_Panels_bmp00075
Undo
Click reject.
All the nodes that you create are placed on the temporary node mark.
