Manufacturing Solutions
To create a node similar to an existing node
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
1.Select the type in subpanel.
2.Click as node.
3.Select a node on the screen.
The x, y, and z coordinates and the system field fill in automatically.
4.Modify the x, y, z coordinates or system ID as needed.
5.Click create.
Undo
Click reject.
All the nodes that you create are placed on the temporary node mark.
