Manufacturing Solutions
To change the AVI window size
1.Select the Options panel.
2.Select the graphics subpanel.
3.Click the switch after AVI window size: and select 1/4 screen, 1/9 screen, or full screen.
When you create an AVI file during animation, the full screen size is retained, or the image is shrunk to the specified size.  The 1/4 screen and 1/9 screen options allow you to reduce the size of the AVI file.  The model size does not affect the file size because the AVI file size is based on the number of pixels and time steps recorded.
