Manufacturing Solutions
To apply a node to a plane
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
1.Select the on plane subpanel.
2.Use the plane and vector collector to specify the plane on which to apply nodes.
3.Pick the locations where you want to apply nodes.
4.Click apply.
Undo
Click reject.
