Manufacturing Solutions
Moving Boundary Analysis
MovingBoundary
L = Billet Length
L1 = Butt Length (Typically 0.5 inches)
L2 = Pocket Length
Flat die without pockets (L2 = 0)
Extrusion direction should be positive Z-axis.
Mesh such that Z=0 at the front end of the billet.
If L1 is the butt length, define a mesh such that it has at least two elements in between Z = 0 (die face) and Z = -L1/2. These elements will not move during the analysis.
Flat die with pockets (L2 > 0)
Hollow Die
Collapsed elements in the billet become very thin in the extrusion direction. This might lead to bad element-grading in the butt area. Therefore, it is advisable to occasionally refine elements in L1 area in the Z-direction.
If using higher-order elements (Hex20 or Hex27), Butt's boundary should match element faces (element faces should fall at Z= -L1).
See Also:
Guidelines for Simulation
