Manufacturing Solutions
Layered Tetra Mesh
Layered Tetra Mesh
Layered Tetra Mesh
The Layered Tet Mesh submenu contains the following macros:
layered_tet_mesh_submenu
Define Boundary Areas:
Create Comps
Shortcut to the Components panel.
Surface Mesh
Shortcut to the Automesh panel.
Normals
Shortcut to the Normals panel.
Organize Faces
Shortcut to the Organize panel.
Def. BL Thickness
Opens the Generate Boundary Layer distributed thickness values dialog, where you can generate boundary layer thickness for components with 2D mesh.
Create Layered Tet Mesh:
Tet Mesh
Shortcut to the Tetramesh panel.
Split Prism to Tets
Allows you to split all prisms (5-noded pyramids) to tetras
Split BC Tets
Allows to you split tetra elements on the boundary so that no element shares more than one face on the boundary
See Also:
Polymer Processing User Profile
