Manufacturing Solutions
Key Rules for Launching HX Jobs
There are a few different ways to launch a HX solver run:
From the HX User Profile
Using HX Job Manager
RADIOSS Solver Command from Windows Start Menu
Directly from Command Prompt
When directly launching the job from command prompt,
Start the run the folder that contains the data deck
HX data deck  includes at least two files: *.hx and * .grf. HX jobs should be always started using the *.hx file. This is critical and if this is not followed, the solver run will crash.  This is because the *.hx file has all the key run control parameters. These parameters has to be loaded before loading the GRF file and they are necessary for a successful run.
