Manufacturing Solutions
Stats
Stats
Stats
The Stats menu provides you with statistics on both the model and the solution. Model Stats gives you information about the model, problem size, and memory requirements. Solution Stats enables you to compute, print, and save integral quantities (mass, force and energy balances; average temperatures, velocities, ..) on different boundaries.
stats_main
The Stats menu
