Manufacturing Solutions
Fitting Material Data
Follow the sections below to fit material data:
Creating a workpiece material
By File:
To curve fit a workpiece material, an input file is required. This input file is specified on selecting the Fit Material > By File option from the context menu in the Select and Assign Material from Database dialog. The format of the input file is shown below. This is followed by the flowstress tabular data (as a function of strain rate and temperature).
 fit_material_code
Enter Data:
To curve fit a Workpiece material, enter data in the fields displayed in the bottom panel of material database. Click OK to complete new material creation.
fitting_material_data
