Manufacturing Solutions
Defining Process Parameters for RTM
Previous topic Next topic Expand/collapse all hidden text
Once the boundary conditions have been set up and assigned, the process parameters should be defined. The process parameters allow you to control the run by specifying the equations/physics to be solved and defining control parameters such as convergence tolerances and the number of iterations/time steps.
Click Parameters on the RTM Utility menu. The Define Altair RTM Analysis Parameters dialog contains the following tabs:
hmtoggle_plus1greySession Tab: General Analysis Data
rtm_parameters_01
hmtoggle_plus1greyProcess Parameters: Process Specific Data
rtm_parameters_02
hmtoggle_plus1greyAir Parameters
The density and compressibility of the air are dependent on air pressure. These two parameters automatically computed when the air pressure value is changed.
rtm_parameters_03
hmtoggle_plus1greyReference Parameters
rtm_parameters_04
hmtoggle_plus1greyUser Defined Commands Tab
This panel is used to specify special commands to control the job. This is an advanced feature.
rtm_parameters_05
