Manufacturing Solutions
Create Bearing
Create Bearing
Create Bearing
The next checkbox on the Extrusion Wizard tab is Create Bearing.
This tool is used to automatically create the bearing profiles. It also computes bearing gap thickness. Key requirements are:
1.Each Bearing BC should have bearing lines in separate collector.
2.Preferred names for line collectors are BearingLines1, BearingLines2, etc.
3.To enable bearing gap thickness computation, activate the checkbox computer gap thickness.
4.Click Create to create the bearing profiles for each bearing BC and the bearing data will be stored in the respective loadcard images.
create_bearing
