Manufacturing Solutions
Assign Material Properties
This block of information is for assigning the material properties to each element MATID. This block also enables you to identify different regions of the mesh with a unique name so as to use it for post-processing or mesh adaptation. A single MATERIAL can be assigned to more than one MATID.
BEGIN MATASSIGN
  USE PVC FOR Resin_1
  USE PVC FOR Extrudate
  USE Steel FOR Container
  USE Steel FOR Die_Block
END
See Also:
Material Models
