Single Action Draw Simulation with Manual Setup
Learn how to perform a single action draw forming process that is set up with manual tooling and positioning.
A video for this tutorial is available here: <installation_directory>\tutorials\tryout_single_action_draw_manual.MP4.
Open the Model
Define the Blank and Material
Create and Assign a Material Based on Test Data
Create a new material with test data from a .xlsx file.
Set Up the Single Action Draw Operation
Configure the Top Die
Configure the Bottom Die
Configure the Bottom Binder
Position the Die Set
Edit the Tool Parameters
Run the Tryout Simulation
Review the Simulation Results
The Analysis Explorer lets you choose a variety of results to review. An animation for each result type is included. By default, the results for thinning are displayed on the formed part.
Figure 1. Results for Thinning
