Apply Constraints
Use the Constraints tool to hold a part so that it maintains its designated position throughout the forming process.
- You can edit individual supports to allow translation or rotation in one or more directions. Double-click on a support to enter editing mode.
- Once a support is created, you can move it away from the model to create a support at a distance by using the Move tool on the microdialog.
Translate or Rotate Constraints
When you create a support, translation is locked in all directions by default; you can edit individual supports to allow translation in one or more directions.
Apply a Support to a Cylindrical Hole
Supports applied to a cylindrical hole are a special case, and have different properties from supports applied to a point, edge, or face.
Microdialog Options
Double-click a constraint to enter editing mode, which opens the Support microdialog.
Translate or rotate the support using the Move tool. Use to place a support at a distance. | |
Align the support normal (perpendicular) to the face. | |
Align the support normal to the draw direction. | |
Align the support to the global axes. |
