Adding Time Domain Results to a View
Add the time results to a 3D view or graph.
You must have already solved the model over the required frequency range and defined a suitable time signal.
  1. Select the graph or 3D view to which you want to add time results.
  2. On the Time analysis tab, in the Add time domain results group, click the relevant request type. From the drop-down list select the request.
