SAR (Specific Absorption Rate)
SAR does not have any special quantities or properties.
POSTFEKO can display specific absorption rate (SAR) values from near field calculations, but if spatial peak SAR of either an 1g or 10g cube is required, a SAR calculation must be requested.
The result of the SAR calculation is displayed in the result palette. For
peak SAR calculations, the position is shown as a cube in the 3DÂ view
Note: The cube for peak SAR calculations is only visible if the geometry is
transparent or cut away.
When viewing SAR results on a graph, the power lost or dissipated per medium is displayed in an info box in the result palette.
