Power
View the quantities and properties that are available for power.
On the Home tab, in the Add results group, click the  Power icon.
The available quantities for power differ substantially based on the selected entity. For example a load does not have the Active power quantity.
Table 1. Quantities for power
Quantity Power FarField NearField
Active power
Loss power
Efficiency
Total radiated power
Power transmitted through surface
Note: The result palette for loads has a similar layout except there is no Port number.
