Changing the Unit of an Axis
Modify the axes units to allow data to be plotted in a familiar unit (for example, to change dBmV/m to dBuV/m) or to shorten the axis text and make it more readable.
As an example, the vertical unit is changed. The step is similar for changing the unit of the horizontal axis.
- Select the trace.
- On the Trace tab, in the Units group, from the Vertical unit drop-down list, select an unit.
