Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
3D views are used to display and interact with the model. You can zoom, rotate and pan around a 3D model using the keyboard,
mouse or a combination of both. You can use a 3D mouse, specify a view or select specific parts of a model. Multiple 3D
views are supported.
Define field or current data using either far field data, near field data, spherical mode data or PCB current data. The
field/current definition is used when defining an equivalent source or a receiving antenna.
Define a medium with specific material properties, import a predefined medium from the media library or add a medium from
your model to the media library.
Defined media can be applied to the model in various ways. Some media settings are applied to regions, others on faces
and wires. The rules for defining media varies between the different solution methods.
Use a periodic boundary condition (PBC) to analyse infinite periodic structures. A typical application of PBC is to
analyse frequency selective surface (FSS) structures.
Create an arbitrary finite antenna array that consists of an array of contributing elements, either with direct feeds for
each element or via indirect coupling, and solve with the efficient domain Green's function method (DGFM).
Use the windscreen tools to define a curved reference surface constrained by a cloud of points, normals and optional U′V′ parameters. The constrained surface is then used as a reference to create a work surface where windscreen layers and curved
parameterised windscreen antenna elements can be created.
Many electromagnetic compatibility and interference problems involve cables that either radiate, irradiate or cause coupling
into other cables, devices or antennas. Use the cable modelling tool and solver to analyse the coupling and radiation.
For a frequency domain result, the electromagnetic fields and currents are calculated at a single frequency or frequency
range. When the finite difference time domain (FDTD) solver is used, the frequency must be specified to convert the native time domain results to the frequency domain.
The excitation of an antenna is normally specified as a complex voltage, but it may be useful to specify the total radiated
or source power instead. The result is then scaled to yield the desired source power level.
A port is a mathematical representation of where energy can enter (source) or leave a model (sink). Use a port to
add sources and discrete loads to a model.
The network schematic view is a panel that shows all general networks, transmission lines and ports (wire and edge
ports) in the model. Use this view to connect general networks, transmission lines, ports and loads.
Define a general non-radiating network using network parameter matrices. In the network schematic view, interconnect
the networks (cascading) and excite or load the network ports.
Define a general non-radiating network by importing a direct component-based network from a SPICE .cir file. In the network schematic view, interconnect the networks (cascading) and excite or load the network ports.
Define an ideal, non-radiating transmission line. In the network schematic view, connect the transmission line to
a port, other transmission lines or general networks.
Obtain multiple solutions for a single model using multiple configurations. Multiple configurations remove the requirement
to create multiple models with different solution requests.
Use an infinite plane or half-space to model a ground plane efficiently. The number of triangles in the model is reduced
as the ground plane is not discretised into triangles.
During the design process, the development of a model can introduce a range of issues that can lead to a non-simulation-ready
model. Use the validation toolset to verify that the model is simulation-ready or to search, detect and flag discrepancies.
The default solver used in Feko is the method of moments (MoM) - surface equivalence principle (SEP). Whether a solver is specified per model, per face or per region, depends on the solver in question.
CADFEKO has a collection of tools that allow you to quickly validate the model, for example, perform calculations using
a calculator, measure distances, measure angles and export images.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
connect the transmission line to a port, other transmission lines or general
networks.
On the Source/Load tab, in the
Loads/networks group, click the TX line icon.
Figure 1. The Add transmission line dialog.
Under Definition methods, specify one of the
following:
Z0, length, attenuation
Z0, length, attenuation, VOP
Z0, length, medium
Specify the transmission line length using one of the following:
To determine the distance between the start point and end point of the
transmission line automatically, select the Determine length from
position.
To specify the transmission line length, in the Transmission
line length field, enter the length.
In the Real part of Z0 (Ohm) field, specify the real
value.
In the Imaginary part of Z0 (Ohm) field, specify the
imaginary value.
Specify one of the following, depending on the selection in 2.
Attenuation (dB/m)
Losses of the transmission line in dB/m.
Note: The propagation
constant is taken as the propagation constant of the medium
in which the start and end ports are located. As a result,
the attenuation specified is added to any losses of this
medium.
Velocity of propagation
The propagation speed through the transmission line relative to
the speed of light.
Medium
The medium used as the background medium for the transmission
line.
The positive port voltage is in the direction of the connected segment
(from the start to the end point of the segment). As a result, the input and output
ports of the transmission line have unique orientations.
[Optional] Select the Cross input and output ports check
box to cross the input and output ports.
In the Label field, add a unique label for the
transmission line.
Click the Create button to create the transmission
line and to close the dialog.
View the transmission line definition in the model tree
(Configuration tab), under Non-radiating
networks.
The transmission line is added to the network schematic view where you can
networks.
