Rectangle
Create a rectangle or a square.
On the Construct tab, in the Create surface group, click the  Rectangle icon.
Tip: Press S,2 to use the shortcut key.
Method 1: Base corner, width, depth
Base corner (C) A corner of the rectangle.
Width (W) The width of the rectangle.
Depth (D) The depth of the rectangle.
Method 2: Base centre, width, depth
Base centre (C) The centre of the rectangle.
