Flare
Create a flare or a pyramid. Flares are often used in the construction of horn antennas and waveguide transitions.
On the Construct tab, in the Create solid group, click the  Flare icon.
Tip: Press C,2 to use the shortcut key.
Method 1: Base centre, bottom width, bottom depth, height, top width, top depth
Base centre (C) The centre of the flare base
Bottom width (Wb) The width of the base in the U axis direction.
Bottom depth (Db) The depth of the base in the V axis direction.
Height (H) The height of the flare, in the N axis direction.
Top width (Wt) The width of the top in the U axis direction.
Top depth (Dt) The depth of the top in the V axis direction.
Method 2: Base corner, bottom width, bottom depth, height, top width, top depth
Base corner (C) The corner of the flare base.
Method 3: Base corner, top corner, bottom width, bottom depth
Top corner (Ct) The corner of the flare top.
Method 4: Base centre, width, depth, height, flare angle 1, flare angle 2
Base centre (Cb) The centre of the flare base.
Height (H) The height of the flare in the N axis direction.
Flare angle (AU) The angle of the flare from the UN plane.
Flare angle (AV) The angle of the flare from the VN plane.
