Cone
Create a cone.
On the Construct tab, in the Create solid group, click the  Cone icon.
Tip: Press C,5 to use the shortcut key.
Method 1: Base centre, base radius, height, top radius
Base centre (B) The centre of the base of the cone.
Base radius (Rb) The radius of the cone base (parallel to the UV plane).
Height (H) The cone height in the N direction measured from B.
Top radius (Rt) The radius of the cone top (parallel to the UV plane).
Method 2: Base centre, top centre, base radius, top radius
Top centre (T) The centre of the top of the cone.
Base radius (Rb)
The radius of the cone base (perpendicular to the line from B to T).
Method 3: Base centre, base radius, height, cone angle
Base radius (Rb)
Height (H) The cone height in the N direction.
Flare angle (A) The growth angle measured from the N axis.
Method 4: Base centre, top centre, base radius, cone angle
Base radius (Rb) The radius of the cone base (perpendicular to the line from B to T).
Flare angle (A)
The growth angle measured from the line defined between B to T.
