Add a request to calculate the transmission / reflection coefficients for a plane
wave interacting with a planar structure.
On the Request tab, in the
Solution requests group, click the Transmission / reflection icon.
Figure 1. The Request transmission / reflection
coefficients dialog.
Under Plane position for phase reference, specify the
location of the plane wave in Cartesian coordinates.
[Optional] Select the Export transmission and reflection
coefficients to file (*.tr) check box to export the transmission
/ reflection data from infinite surface structures.
Note: To export a valid .tr file, your model must either
contain a periodic boundary condition (PBC) or a planar Green's
function.
In the Label field, add a unique label for the
request.
Click Create to request the transmission /
reflection coefficients result and to close the dialog.
