Creating an Isotropic Layered Dielectric (2D)
Create a layered-dielectric medium.
On the Construct tab, in the Define group, click the Media icon. From the drop-down list, select the Layered dielectric (2D) icon.
- In the Label field, enter a unique label for the dielectric.
- In the Thickness field, enter a value for the layer thickness.
In the Dielectric material field, select one of the
following options:
- To add a dielectric layer consisting of a predefined dielectric, select the dielectric.
- To add a dielectric layer consisting of a dielectric, which is not yet defined in the model, click the icon to define the dielectric or add a dielectric from the media library.
- [Optional] To add an additional layer, click Add.
- [Optional] To remove a layer, click Remove.
- Click Create to create the dielectric and close the dialog.
