Create a frequency-dependent dielectric using the Cole-Cole
method. The method is similar to the Debye relaxation but makes use of
an additional parameter to describe the model.
On the Construct tab, in the Define group, click the Media icon. From the drop-down list, select the Dielectric medium icon.
Figure 1. The Create dielectric medium dialog (Cole-Cole).
In the Definition method field, from the drop-down list select Cole-Cole.
In the Relative static
permittivity field, enter a value for εs.
In the Relative high frequency
permittivity field, enter a value for ε∞.
In the Relaxation frequency
field, enter a value for fr.
In the Attenuation factor field,
enter a value for α.
[Optional] Specify the magnetic properties of the
dielectric.
[Optional] In the Mass density
(kg/m^3) field, enter a value for ρ.
In the Label field, enter a
unique label for the dielectric.
Click Create to create the
dielectric and close the dialog.
