Adding a Load
Apply an impedance load to a wire port, microstrip port, FEM line port, a general network or an ideal transmission line.
On the Source/Load tab, in the
Loads/networks group, click the
Add load icon.
Figure 1. The Create load dialog. -
Under the Load Type
drop-down list, specify one of the following:
- Complex impedance
- In the Real part field, specify the real part of the complex impedance in Ohm.
- In the Imaginary part field, specify the imaginary part of the complex impedance in Ohm.
- Series circuit
- To specify a resistor, select the Resistor check box and in the Resistor (Ohm) field, enter a value in Ohm.
- To specify an inductor, select the Inductor check box and in the Inductor (H) field, enter a value in Henry.
- To specify a capacitor, select the Capacitor check box and in the Capacitor (F) field, enter a value in Farad.
Note: If no option is selected, the result is a short circuit. - Parallel circuit
Note: If no option is selected, the result is an open circuit. - SPICE circuit
- In the Filename field, browse for a one-port SPICE circuit file to define a load between two pins.
- Touchstone file
Touchstone file (.s1p,
.z1p, .y1p).Note: If the load is added to a port that has a voltage source, the load is placed in series with the voltage source.
.z1p, .y1p).
- Complex impedance
- In the Label field, add a unique label for the impedance load.
- Click the Create button to create the load and to close the dialog.
