Import near field data from Feko field on a Cartesian
boundary (.efe and / or .hfe), Sigrity input file
(.nfd), Orbit / Satimo measurement file
(.mfxm) or a CST near field scan (.nfs) to create
a near field data definition. Use the near field data definition when defining an equivalent
source or receiving antenna.
On the Construct tab, in the Define group, click the Field/current data icon. From the drop-down list
select Import near field data from file.
In the Use data block number field, specify the data
block number that corresponds to the near field data at a specific
frequency.
Select the Swap source and field validity regions check
box if the fields on the opposite side of the aperture (inside the boundary) are
equivalent to the measured or calculated field values.
In the Label field, specify a unique label for the near
field data.
Click Create to define the near field data and to
close the dialog.
