Introduction to the Component Library
The component library contains a list of components that can be used as a new model or be added to an existing model.
- Antenna
Each antenna component is defined by fully parametric geometry, created using variables and mathematical expressions. When a variable is modified, any item in the antenna that references the variable is re-evaluated and updated.
Antennas are indicated by the icon in the library.
- Platform
A platform is geometry that is used as a mechanical structure for mounting antennas, for example, a tower truss.
Platforms are indicated by the icon in the library.
