For a complex cable harness, it is not a simple task to find a specific cable
instance in the 3D view. Use the “Find cable” tool to locate a
cable instance.
On the Cables tab, in the
Tools group, click the Find cable icon.
Under Filter, from the Cable
Harnessdrop-down list, select the cable harness you want to find.
[Optional] Under Filter, from the
Connectordrop-down list, narrow down the search by specifying a connector
in the cable harness.
Pathdrop-down list, narrow down the search by specifying a connector
[Optional] Under Filter, from the Cross
sectiondrop-down list, narrow down the search by specifying a defined
cable cross section in the cable harness.
[Optional] Under Filter, from the Cable
instancedrop-down list, narrow down the search by specifying a cable
instance in the cable harness.
Specify the route along which to search for a cable instance.
Under Routes, select one of the following options:
To specify a cable instance in a specific route, clear the
All routes check box.
To view all routes that satisfy the above criteria, select the
Cable instances which satisfy the search criteria are listed in the
table.
Click the cable instance in the table to highlight the cable instance in the
3D view and model tree.
