A cable connector is the end terminal for a cable.
On the Cables tab, in the
Create instance group, click the Cable connector icon.
Figure 1. The Create connector dialog.
Specify the position of the cable connector.
Under Position, select one of the following:
To select the start or end point of a cable path, click Cable
path terminal.
To select the start or end point of a predefined cable path,
from the Path terminaldrop-down list, select the cable path you want to
use.
To create a cable path, which is not yet defined in the model, click
the icon to define a cable path.
To specify the X, Y and Z coordinates, click 3D
coordinate.
Add pins to the cable connector. Pins represent connection points between
cables and cable components (for example, capacitors and inductors). Connections to
the pins are made in the cable schematic view.
Under Housing, add pins to by clicking the Add button. Remove a pin by clicking the Remove button.
In the Label field, add a unique label for the cable
connector.
Click the Create button to create the cable
connector and close the dialog.
