View the original base element and the full finite antenna array in the 3D view.
After a finite antenna array has been created, the base (original) element is indicated by
green hatching in the 3D view.
Figure 1. The base (original) element is indicated by green hatching in the 3D view.
Note: A large finite array with non-uniform distribution will affect the 3D rendering and
performance when modifying large arrays in CADFEKO and the 3D rendering
in POSTFEKO.
