Distribution Follows in *.pre File
This option defines the finite antenna array by specifying the distribution and excitation for each individual element directly in the .pre file.
Figure 1. The FA - Finite array analysis dialog, with Distribution follows in *.pre file selected.
Parameters:
Number of elements
The number of antenna array elements specified in the antenna array.
X, Y, Z coordinate
Cartesian coordinates for the location of the respective antenna array elements.
Rotation around X axis (degrees)
Angle of rotation around the X axis in degrees.
Rotation around Y axis (degrees)
Angle of rotation around the Y axis in degrees.
Rotation around Z axis (degrees)
Angle of rotation around the Z axis in degrees.
Element excitation
If the Uniform distribution or calculated from plane wave option is selected, the array elements will either have a uniform distribution or the distribution will be calculated from the plane wave if a plane wave is present in the model. If the Specify amplitude and phase for each element option is selected, the user can specify the excitation for each element.
Magnitude scaling
The excitation magnitude for the respective element is scaled relative to the base element.
Phase offset (degrees)
The phase offset in degrees for the respective element relative to the base element.
