Single Conductor Cable
This option defines a single cable.
Figure 1. The CD - Cable cross section definition dialog.
Parameters:
Cross section label
The label of the cross section.
Core
PEC
Select this option to set the core of the cable to PEC.
Material label
The label of the metallic medium (as defined in the DI card) to be used for the core.
Core radius
The radius of the core.
Insulation
Material label
Thickness
The thickness of the material to be used as insulator.
Cable per-unit-length parameters accuracy
The Cable per-unit-length parameters accuracy can be increased from Normal (default) to High or Very high.
