Adding a Wire Port to the Monopole
Define a wire port on the monopole. A voltage source will be added to this port.
  1. Select the monopole.
    1. In the model tree, select Line1.
    2. In the details tree, select Wire1.
    Tip: Wire1 is the wire element associated with Line1.
  2. Define the wire port on the selected wire (monopole) using one of the following workflows:
    • On the Source/Load tab, in the Ports group, click the  Wire port icon.
    • On the details tree, a right-click context menu is available. Select Create port > Wire port.
  3. Use the default port settings.
  4. Click Create to create the port and close the dialog.
