Viewing the Near Field Results (3D)
View the near field results in the 3D view and add a legend and contours.
Add the near field data to the 3D view.
  1. On the Home tab, in the Add results group, click the  Near field icon. From the drop-down list, select NearField1.
View the electric field in dB.
  1. On the result palette, in the quantity panel, select the dB check box.
For the purposes of this example, the magnitude of the Ey component of the field is to be displayed.
  1. On the result palette, in the quantity panel, clear the X check box and the Z check box.
Add a legend to the 3D view (top left).
  1. On the 3D View contextual tabs set, on the Display tab, in the Legends group, click the  Top left icon. From the drop-down list select NearFields.
Add contours to the near field result.
  1. On the 3D View contextual tabs set, on the Result tab, on the Contours group, click the  Show contours icon.
Specify the number of contours for the near field.
  1. On the 3D View contextual tabs set, on the Result tab, in the Contours group, click the  Position icon. Click Number of contours and set its value to 11.
