Optimising the Bandpass Filter with HyperStudy Using a POSTFEKO Session
Configure the bandpassfilter.pfs file with the S11 data to minimise the reflection coefficient in HyperStudy.
Simple examples demonstrating antenna synthesis and analysis.
Simple examples demonstrating antenna placement.
Simple examples demonstrating radar cross section (RCS) calculations of objects.
Simple examples demonstrating electromagnetic compatibility (EMC) analysis and cable coupling.
Simple examples demonstrating using waveguides and microwave circuits.
Simple examples demonstrating phantom and tissue exposure analsysis.
A simple example demonstrating the time analysis of an incident plane wave on an obstacle.
Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO (large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
Use application automation to perform operations with CADFEKO and POSTFEKO. Typical tasks include repetitive tasks, tasks that require several steps, or calculations.
Increase productivity when dealing with predictable and repeatable POSTFEKO sessions (for example, exporting a report) using application automation. Use an automation script to configure a session and export a report that highlights the antenna properties of the model.
Design matching antenna circuits with Optenni Lab and use the circuit in Feko.
Design a bandpass coupled line filter with HyperStudy as optimisation engine and Feko as the computational solver.
Learn the four approaches in HyperStudy to modify a model and interpret the results.
Learn the HyperStudy workflow. Learn study setup and configuration phases.
Configure the HyperStudy setup and perform the optimisation. Minimize the reflection coefficient.
Generate a model with the optimum values in Feko and solve.
