Meshing the Model
Create the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
- Use the same mesh settings as for MoM Model.
- Mesh the model.
Simple examples demonstrating antenna synthesis and analysis.
Simple examples demonstrating antenna placement.
Simple examples demonstrating radar cross section (RCS) calculations of objects.
Simple examples demonstrating electromagnetic compatibility (EMC) analysis and cable coupling.
Calculate the shielding factor of a hollow sphere with finite conductivity. The sphere is constructed from a lossy metal with a thickness of 2.5 nm.
Calculate the shielding factor of a hollow sphere with finite conductivity. The sphere is solved using MoM.
Calculate the shielding factor of a hollow sphere with a finite conductivity. The sphere is modelled with FEM.
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
Define the calculation requests in CADFEKO.
Run the computational electromagnetic (CEM) validate tool to perform basic validation on the CADFEKO model.
Run the Solver to compute the calculation requests.
Compare the shielding factor results for the sphere using the MoM and FEM solution methods.
Calculate the coupling between a monopole antenna and a nearby shielded cable that follows an arbitrary path above a ground plane.
Calculate the segment current on a magnetic-field probe as a function of the plane wave incidence angle.
Calculate the safety zones around a Yagi-Uda antenna based on radiation INIRC88 and NRPB89 standards. View the safety zone ISO surfaces.
Simple examples demonstrating using waveguides and microwave circuits.
Simple examples demonstrating phantom and tissue exposure analsysis.
A simple example demonstrating the time analysis of an incident plane wave on an obstacle.
Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO (large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
