Defining Calculation Requests
Define the calculation requests in CADFEKO.
Simple examples demonstrating antenna synthesis and analysis.
Calculate the radiation pattern and input impedance for a half-wavelength dipole at 74.9 MHz. The dipole length is 2 m with a wire radius of 2 mm.
Calculate the radiation pattern for a half-wavelength dipole in front of a cuboid. View the effect of the cuboid on the radiation pattern.
Calculate the radiation pattern of a dipole in front of an electrically large plate. Several techniques available in Feko are considered and the results and resource requirements compared.
Calculate the radiation pattern for a wire monopole antenna on a finite ground plane. The ground plane is modelled as a circular PEC ground plane.
Calculate the radiation pattern for a horizontally polarised Yagi-Uda antenna consisting of a dipole, a reflector and three directors at 400 MHz. The antenna is located 3 m above a real ground which is modelled with the Green’s function formulation.
Optimise a Yagi-Uda antenna design to achieve a specific radiation pattern and gain at 1 GHz. The Yagi-Uda antenna consists of a dipole, reflector and two directors.
Calculate the radiation pattern and input impedance for a log periodic dipole array (LPDA) antenna. Non-radiating transmission lines are used to model the boom of the LPDA antenna.
Model a microstrip patch antenna using two feed methods (pin feed, microstrip edge feed). The dielectric substrate is considered as a finite substrate and an infinite planar multilayer substrate.
Calculate the input reflection coefficient of a proximity coupled patch antenna on an infinite substrate.
Calculate the input reflection coefficient of an aperture coupled patch antenna. Use continuous frequency sampling to minimise runtime. Compare results for a finite and infinite dielectric.
Calculate the far field pattern of a pyramidal horn antenna at 1.645 GHz.
Calculate the input impedance and radiation pattern of a dielectric resonator antenna (DRA) with a coaxial pin feed on a finite ground.
Calculate the radiation pattern of a dielectric lens antenna. The lens is illuminated by an equivalent far field source with an ideal cosine pattern. The lens structure is modelled using the ray launching geometrical optics (RL-GO). Compare the RL-GO solution with a hybrid FEM/MoM solution.
Calculate the input impedance of a windscreen antenna constructed from wires. The windscreen consists of a layer of glass and a layer of foil.
Calculate the current distribution and far fields for a MIMO elliptical ring antenna. Use characteristic mode analysis to calculate the results for different modes.
Calculate the far field pattern for a single element in an infinite two-dimensional array of pin-fed patch elements. The infinite patch array is modelled using periodic boundary condition. Calculate the approximated far field pattern for a 10x10 element array.
Compute the broadside pattern for a single element in an infinite patch array and for an 10x10 element array. The phase shift is specified in the u1 and u2 vector directions.
Compute the broadside pattern for a single element in an infinite patch array and for an 10x10 element array. The phase shift is determined from the beam pointing (“squint angle”).
Compute the squint pattern for a single element in an infinite patch array and for an 10x10 element array. The phase shift is specified in the u1 and u2 vector directions.
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
Create the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
Run the computational electromagnetic (CEM) validate tool to perform basic validation on the CADFEKO model.
Run the Solver to compute the calculation requests.
Compute the broadside pattern for a single element in an infinite patch array as well for an 10x10 element array. The phase shift is determined from the beam pointing (“squint angle”).
View and post-process the results in POSTFEKO.
Calculate the radiation pattern for an array of arbitrarily placed pin-fed patch antennas. Use the finite array tool to construct the array and the numerical Green's function method (DGFM) to minimize computational resources.
Simple examples demonstrating antenna placement.
Simple examples demonstrating radar cross section (RCS) calculations of objects.
Simple examples demonstrating electromagnetic compatibility (EMC) analysis and cable coupling.
Simple examples demonstrating using waveguides and microwave circuits.
Simple examples demonstrating phantom and tissue exposure analsysis.
A simple example demonstrating the time analysis of an incident plane wave on an obstacle.
Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO (large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
