Calculate the S-parameters (coupling) over a frequency range for three monopole antennas located near the front, middle
and rear of a Rooivalk helicopter mock-up.
Create the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation
in the Solver.
Calculate the coupling between a helix antenna and a Yagi-Uda antenna located in front of a large plate. Reduce computational
resources by using the uniform theory of diffraction (UTD) and an ideal receiving antenna.
Calculate the coupling between two horn antennas separated by 60 wavelengths. A metallic plate between the horn antennas
blocks the line-of-sight coupling. Replace the horn antennas with a far field equivalent source and receiving antenna.
Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO
(large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
Request the S-parameters for the model. Add the three ports in the S-parameter
request and specify a reference impedance of 50Ω each. Set the three ports to active.
