Measuring an Angle
Use the angle measuring tool to measure or validate the angle (in degrees) between three points in a model.
  1. On the 3D View contextual tabs set, on the Mesh tab, in the Tools group, click the  Measure angle icon.
  2. On the Tools tab, in the Tools group, click the  Measure angle icon.
  3. Under Point1, use Ctrl+Shift+left click to snap to points (for example, named points, geometry points, geometry face centre, geometry edge centre, mesh vertices and grid).
  4. Repeat Step 3 for Point 2.
  5. Repeat Step 3 for Point 3.
    The angle in degrees is displayed in the Angle (degrees) field.
  6. Click Close to close the dialog.
    Figure 1. The Measure angle dialog.
