Measuring an Angle
Use the angle measuring tool to measure or validate the angle (in degrees) between three points in a model.
  1. On the Tools tab, in the Tools group, click the  Measure angle icon.
  2. Under Point1, use Ctrl+Shift+left click to snap to points (for example, named points, geometry points, geometry face centre, geometry edge centre, mesh vertices and grid).
  3. Repeat Step 2 for Point 2.
  4. Repeat Step 2 for Point 3.
    The angle in degrees is displayed in the Angle (degrees) field.
  5. Click Close to close the dialog.
    Figure 1. The Measure angle dialog.
