VRML parameters and parameter types
Parameter Type
Value
SFBool
Single Boolean
Any single Embed value
SFFloat
Single float
SFInt32
Single integer
SFVec2f
Vector 2 floats
Embed vector of two elements
SFVec3f
Vector 3 floats
Embed vector of three elements
SFColor
Color
SFTime
Time
double
SFRotation
Rotation
Embed vector of four elements (x, y, z, angle) axis-angle
MFFloat
Multiple floats
Any vector
MFlut32
Multiple integers
Any vector
MFVec2f
Multiple vectors of 2
n x 2 matrix
MFVec3f
Multiple vectors of 3
n x 3 matrix
MFColor
Multiple colors
n x 3 matrix
MFTime
Multiple times
Any vector
MFRotation
Multiple rotation
n x 4 matrix
VRML parameters have the following settings:
If the parameter is preceded by
Then
A red X
It cannot be selected as a block input wire
A green checkmark
It has already been selected as a block input wire
An empty box
It has not yet been selected as a block input wire
To select a parameter as a block input wire, highlight the keyword and press Make%20Block%20Input%20button. The selected parameter appears in the Block Input Wires window.
