Using the constraint block with a custom implicit solver
In the ID box in the constraint dialog box, enter the number that Embed uses to sort the block when presented as a vector in a user-written solver. Embed does not require the ID to be unique or contiguous; it sorts them in sequential order. The default is 0.
